Terragen 3
Website:Terragen 3
Planetside Software’s Terragen 2 is a highly realistic landscape generator used to create background images in films and games such as Star Trek: Nemesis, Stealth and The Imaginarium of Dr. Parnassus. Our script renders a single frame of a snowy mountain scene at 640 x 480 on all the available CPU execution units.
Intel Core i7-5930K
Overclockers UK Infin8 Nebula
Intel Core i7-4790K (4GHz/4.8GHz)
Utopia Pandora
PC Specialist Apollo 703
Intel Core i5-4690K (3.5GHz/4.8GHz)
AMD FX-8350 (4GHz)
200
300
400
500
600
700
800
Seconds, lower is better
Cinebench R15 64-bit
Website: www.maxon.net
Cinebench uses Maxon's Cinema 4D engine to render a photo-realistic scene of some shiny balls and weird things (we miss the motorbike). The scene is highly complex, with reflections, ambient occlusion and procedural shaders so it gives a CPU a tough workout.
As Cinema 4D is a real-world application - used on films such as Spider-Man and Star Wars - Cinebench can be viewed as a real-world benchmark.
Intel Core i7-5930K (3.5GHz/4.55GHz)
Utopia Pandora
AMD FX-8350 (4GHz)
Intel Core i5-4690K (4GHz/4.8GHz)
500
750
1000
1250
1500
Score, higher is better
Power Consumption
For the power consumption tests, we measure via a power meter at the wall, so the numbers below are of total system power draw from the mains, not the power consumption of a CPU itself. Measuring the power draw of any individual component in a PC is tricky to impossible to acheive. We use Prime95's smallFFT test to put the CPU under 100 percent load, while idle power results were taken with the PC sitting at a Windows Aero-enabled desktop.
Utopia Pandora
Cyberpower Achilles Pro 4K (4790K + GTX 780)
200
300
400
500
600
Watts, lower is better
